Low Compression
  • Thread starter Thread starter Turbo
  • Watchers Watchers 7
That was warm. I just attributed it to being at 8500 ft above sea level. My dad's car was nearly identical. I think I will go rent a compression tester and see if the values change. I am using an older harbor freight one.
I wouldn't bother. Technically, your numbers are fine in terms of percentage difference across cylinders.
As you know, being technically correct is the best kind of correct.
