suchamoneypit
EDIT: Problem solved, both my HPFP housings were bad. New HPFP housing solved the problem. More detailed explanation in a response posted below.
Hey everyone, been pulling my hair on this one. Here's the scenario. Car is running fine (2011 speed3), for 1.5 years. I buy brand new Corksport HPFP internals, and another used HPFP. So I have the one on my car, and this spare. I clean up, polish, and install the Corksport internals on this used HPFP, to swap with the one on my car.
I take off my HPFP my car has been using, and install the "new" one with the corksport internals. My car now has hesitation, sometimes severely, when accelerating around 3000rpm and below. Right after I take this turn, my throttle pedal position is consistent, but you see the car stutter (and can see it on the tachometer). In logs, this is shown as load increasing to around .8-.9, but fuel pressure staying at ~85psi. When the car "recovers" and starts to accelerate normally, the fuel pressure shoots up to the proper ~1800psi. Once the car is at proper pressure, It drive normally, and I can take normal WOT logs that don't have any issues.
So I take my spill valve off my known-good HPFP, and install it in the "new" used HPFP with my corksport internals, thinking its a bad spill valve.
Still does it, so now I take my old working HPFP, reinstall its known working spill valve back, along with my brand new Corksport internals. So Im using my confirmed working HPFP setup, with brand new corksport internals. Car still has the problem.
I now replace my fuel relief valve with a brand new one. Still have the problem.
TL;DR
-confirmed working HPFP spill valve + HPFP housing, brand new Corksport HPFP internals
-brand new fuel relief valve
-hesitation on acceleration ~3000rpm and below
-shows in logs as requested throttle going up, load going up to .8-.9, but fuel pressure staying at ~85psi.
-Video of it in action
-data logs attached to post
Anyone know what the problem could be? And why installing new HPFP internals could prompt this problem?
TL;DR
