Mazdaspeed 6 & Mazdaspeed 3 AWD - T-Case Billet Mount
Billet Aluminum Transfer Case Mount​
Mazdaspeed 6 & AWD Swapped Mazdaspeed 3
Upgrade the ugly and heavy factory transfer case mount with a precision CNC-machined billet aluminum replacement. Designed and manufactured by Contrive Design Innovations, this mount removes unnecessary material and features from the original cast steel part while maintaining the strength needed for high-performance AWD applications.
The result is a lighter, stronger, and cleaner solution for Mazdaspeed drivetrains.
Significant Weight Reduction
  • Factory mount: 4.02 lb cast steel
  • Contrive billet mount: 1.54 lb 6061-T6 aluminum
  • Over 60% weight reduction
CNC Machined Billet Construction
  • Precision machined from 6061-T6 aluminum
  • Optimized structure removes unneeded material from the factory design
  • Maintains excellent rigidity and durability
Direct Bolt-On Replacement
  • Designed specifically for Mazdaspeed 6 & AWD Swapped Mazdaspeed 3
  • Reuses factory mounting locations and hardware
  • No modifications required
Clean Performance Aesthetic
  • Raw machined aluminum finish (no color options currently)
  • Lightweight motorsport-inspired design
  • Subtle Contrive logo machining
There are already people that make bearing caps for inside the transfer case. I've heard it claimed that people with high-power MS6's have been known to bust the main housing of the transfer case. I've not seen this myself, but I've heard it claimed. And wondered if there was any possibility to add an external brace to it. I've heard of that kind of option for other vehicles with high power mods and just wondered. If not really necessary or not possible, I don't really know, just asking.
