speedyboi
So I recently decided to spice up my life and buy a 2007 MS3, but I have a problem.
I'm experiencing misfires at idle, and it will throw a code for random misfires and cylinder specific misfires after a driving cycle.(I also believe I have a vacuum leak) The Car will pull all-the-way till Sunday and drives fine, but it just misfires at idle.(Also smokes a lot likely b/c of clogged cats) I bought it from a buddy who replaced the PCV right before he sold it to me. We did a compression test and all cylinders are in spec. (175 170 165 175) It no longer seems to be burning oil after the PCV replacement, so thats good. I thought that maybe fuel had something to do with it so I pulled the plugs and coils, and from left the right plugs 1&3 looked good while 2&4 looked like they were leaning out.(But no leanout code) It was misfiring on 2 so I swapped the coils between 2&3 to see if that was causing a problem and the misfire jumped to 1? So then I switched coils 1&4 and the misfire stayed on 1. I decided to pull off the intake manifold and fuel rail to see if the stock injector seals had failed and if the valves were clogged with carbon build up. Long story short, I found no seals and It looked like Cyl 4 had some leaked fuel in the injector port. Got some seals coming in to solve that problem and I'm also cleaning the injectors/ports/valves to see if this will solve the problem. If this doesn't work I'm worried it could be bad injectors on 2 and 4, or maybe bad valves? All the other forums I've looked at don't have posts about this issue so I'm hoping I can find my answers here.
Thanks
Thanks
