I recently posted an issue with the drain tube for the HVAC system wicking water back to the firewall and soaking the body gasket, then leaking into the cabin...
https://mazdaspeeds.org/index.php?threads/wet-passenger-floor-insulation.9008/
I seem to still have water collecting on the floor, a lot less, but not under the rubber backed insulation along bottom of the firewall like with the drain tube water. This water leaks from further up and drops on the wiring at the base of the HVAC unit. Insulation underneath remains dry this time.
This was after a 15-20 minute drive home from work, fan on high with AC, set at 68deg with amb outside at 55deg. Same with temp set at 59deg and amb @ 71deg. The leak happens pretty much like clockwork when the AC is run and the fan is on high. If I shut off the AC, no water. I can recreate the problem in my garage as well. I have tested the evaporator sensor as per the manual, 57deg = 6.63ohm, therefore within spec (evap sensor is nolonger available
I have seen the water drip. It appears in a single dribble like a few cc from a syringe, then stops. Its not running down the firewall but like it could be from a seam about where the evaporator sits. The foam insulation around the evap tubes is dry so I dont think its condensation from there.
Question...
Is there a drain that could be blocked inside the case that drains water from around or above the evaporator unit to the lower pan? If someone has a case open or could have a look inside, maybe take pix, Id appreciate it. Any help welcome.
Can the AC system be too cold? I have set the car to 59deg on recirc. and my thermometer read 57deg after 5min run time. I have tossed the idea around that the evaporator is freezing up and the dribble is from it thawing. However not much else related to that issue matches up. Airflow remains good and AC blows ice cold all the time with no rise in humidity.
In the end, if the water wasn't happening there would be no issue. The system operates to my satisfaction. I've exhausted all my tiny brain can surmise.
I have recently had the system recharged to 1.01lb after removing the HVAC unit to replace the lower pan (June) and replaced the cabin filter (July).
Question...
