pwdunmore
Hello All,
I took my car to get an alignment at a mazda dealership because I put some KW coilovers on the car.
I thought the rear control arms had adjustment bolts to change the camber but they said they do not.
Right now I have -2.4 on the driver's side and -3.4 on the passenger. They didn't advise of any components being worn out or damaged.
I thought there was stock rear camber adjustment because I found this on the interwebs: (I clearly see these on my car)
So if I went in with (-2.4 & -3.4) and had the same after, they didn't touch these to adjust them? Or do I need to get adjustable camber arms in the rear?
Everything else on the alignment is within spec but I look like a stance boi on the side right now and the inners of the rear tires definitely won't last long like it.
Spec: Before
Driver Passenger
Front Camber = -0.8 -0.9
Front Toe = 0.35 0.01
Rear Camber = -2.4 -3.3
Rear Toe = 0.18 0.36
Spec: After
Driver Passenger
Front Camber = -0.8 -1.0
Front Toe = 0.1 0.1
Rear Camber = -2.4 -3.4
Rear Toe = 0.19 0.18
Lastly, I called mazda canada and they said there is no camber adjustment stock on the car. But why are there these adjustment bolts/washers there?!?!
Spec: Before
Driver Passenger
Spec: After
Driver Passenger
Front Toe = 0.1 0.1
