Vice Grips worked on my stuck-on nuts, no slippage.Those fuckers are on there good. Flare nut wrench had the same result. Gonna hit it with some fire today and see if that helps.
KinkyVice Grips worked on my stuck-on nuts, no slippage.
Pretty easy to do the flares yourself if you have the fitting and tool, working from home certainly has it's perks. Good luck
You can reuse the old fittings if you can't find replacement ones. Unless they are rounded off. Even if that's the case go to a junk yard and grab those lines or fittings if possible
So got it sorted?I only ended up with 1 "bad" fitting. It was seized inside the master pretty good and at this point I was ready to sacrifice it thinking it wouldn't be hard to get a new on - I was wrong. The fitting is all chewed up and I wouldn't put it on anything else. Hell I even went as far as cutting it off the stock pipe and put a new one on. That's when I realized the threads don't actually screw into the master...they just kinda wobble down. Eh not too worried about it - I'll figure out whatever I need and have them for the future.
