Speed777
Good evening,
I'm getting ready for a bigger project with my car. I'm getting ready to do corksport cst4, cs cams, cs exhaust manifold, CS small core front mount intercoller etc.
I'm running a turbosmart dual port bov at the moment and wanted to know from any members here which front mount intercooler kit will clear with this turbosmart valve. The reason of my question is because i came across a review on corksport webpage about a client back in 2020 who bought the small core front mount kit and end it up having to use the shitty oem bpv.
Can any of you guys that are running turbosmart dual port BOV tell me which small core kit are you running in order to clear? I also thought of COBB FMIC option but I'm not sure if the piping clears the turbosmart dual port bov .
This is very important to me because if im not able to clear this valve I'll end up staying with my ETS top mount intercooler setup. If this is the case i would also have to consider keeping internal waste gate option due to the fact that with top mount intercooler i can't install external wastegate on CS exhaust manifold due to clearance issues. I can't either go the housing option corksport has because it states it doesn't clear with aftermarket DP. So if anyone can help me here and share some light so I can make a wise money spending decision. Thanks in advance for your help
