nickw8855
i have been dealing with the headache of a problem and so this is my first time posting here. a few months ago the 6 really started acting up. fuel trims started hanging out around -15 on both LTFT and STFT. boost would only get to 12psi WOT (tuned for 22). High pitched squeal coming from hpfp. Not hitting desired HPFP psi (demand is 1660 and only sending 1400psi. ) AFR's hangout around 14.5-14.7 at idle. here's some logs. I'm a dummy so any help would be appreciated. I've spent days on these forums trying to look through threads and have replaced so many darn sensors, I'm tired of throwing money at this thing. I should also add, recently HPFP rebuilt, new CS injector seals, new spark plugs @.026 gap, new pcv, new prv, cant find a boost leak. no check engine lights.
