i switched to the stage 2 map as i don't have the stage 0 on my AP at the moment. still had the same issue plus crazy knock (8kr), i drove for about 8km on itYou flash a stage 0 map yet?
Agreed, its really bugging meOK then, shit's haunted.
2 weeks isn't that bad of a wait. Try being 4-6 weeks out for transmission work like my dealership is. I have a 2020 Corvette I need to put a transmission in and it's been there two weeks now waiting on me to get to it.
Here's what I want you to do. Do a wet and dry compression test both cold and hot. Report back with the numbers.
As for the lean condition if you're going WOT the ECU isn't monitoring the fuel trims. It's switching from closed loop to open loop.
Did you reflash the map as suggested and see if that made any change?
If only you could get the stage 0 back....oh wait there isI know, im just anxious to get it working again. Its already been having this issue for 2 weeks.
Ill do the compression test wet and dry, ill report back in a couple days for that.
As for the tune, i deleted the stage 0 off my AP but i put on the stage 2 and it had the same issue, the only thing im missing fro stage 2 is the intercooler I think
Also I wasn't WOT, i think i was close too it but I don't think it was WOT so fuel trims should still be working
https://www.cobbtuning.com/maps
Do me a favor and measure the id of the intake with the filter off.
i know there's a way to get it back, there's no need to tho we were just testing to see if a different tune would change anything
Wether or not it seems redundant it would help to just reflash to that as a test procedure. Instead of focusing on the level of boost you're trying to target, focus on the other issues that your car is currently displaying.
Low compression, lean conditions, failure to build boost. It sounds like a mess. Personally I think your motor is shot.
If you can't build compression you can't get the turbo to spool properly. It just won't happen. The turbo is reliant on the ability for the engine to push air out. If a cylinder can't compress the air then it's essentially not working. Even during a cruising condition you could drive it relatively ok with low compression but not have enough to make power.
There is also the tune factor. Your WGDC could be messed up. You said you were tuned by Freektune right? He's a solid tuner and knows his stuff. I have yet to hear of anyone having an issue with him unless it's something they caused on their end of things.
Have you tried to reach out to him to see what he thinks? Was his tuning finalized and on the last map?
.....click get it then add to cart check out and it'll be available in your accounts iirc they email you a link and tell you how tooI can't seem to find where im supposed to download the file, i see the stage 0 but i can't download it, my only options are word and pdf
That makes sense, but doesn't explain the issue. I don't see how it could be tune related considering it started on a known good tuneI was tuned by Freektune on my car and of course on the first revision you're not going to build more than probably 10-12 psi. The revisions after that slowly increase boost levels while also adding timing and other things. It's a slow drawn out process where if you had been able to be Dyno tuned live it would be done within a few hours.
so maf housing diameter is little less then 3 inches and same for the intake elbow and then the TIP starts at 3” then shrinks down to the 2.16” turbo inlet
So stage 1+sfWell this is clearly not a stock 2.5" intake. Try flashing an OTS for a 3" intake.
