ThePattyWagonMS3
Currently running a v3 AP in my 08MS3GT with 81k miles. Trying out up to STG 1 93 tune until I get HPFP upgrade within the month. HPFP actual pressure isn't dropping below 1600 ever at WOT. However actual AFR is running at a 12.2-12.35 with boost at WOT. Stock intake system and everything. I cleaned up the MAF and it made no difference. I have heard that AFR should be between 11.4 and 11.7 at WOT.
Went back to STG 0 tune and car ran really lean at 13.5 or so until it normalized in the 11s at 4000-5000rpm and then after 5000 ran really rich down to like 9.5 at 6k rpms.
Tried safe mode as well and car ran consistently a little lean at a 12.05 at WOT.
Completely new to tuning and Id love help interpreting these results. If I need to run it in safe mode until HPFP that totally fine but it seems that because pressure isn't dropping on the HPFP that might not be the issue? Stage 1 reads it can be all stock including the HPFP. Would love to donate to this forum given some good information.
Logs: All taken same time with the 3 different tunes. Not sure why stage 0 reads that throttle wasn't at 76 it was to the floor. Attached down below of the knowledgeable people wouldn't mind taking a look.
Thanks for any help offered!
