OEM Rear Camber Arm Bolt
Skunky82
Anyone have the length, thread pitch, and size of the inner camber arm bolt handy? Rounded the passenger side bolt and still working on getting it out.
Figured I'd pick up a replacement while I'm out getting an extractor set.
Don't remember the thread, but it's the same as your toe arm bolts, shock bolt, and control arm bolts. The only difference between all of them are the lengths. So if your car is on jack stands, pull one out and hit up your local hardware store. FYI The toe arms are the easiest to bolt up and unbolt.
