Oil pump chain guide bolts?
Ssinstaller
In the process of fixing my slipped timing, I noticed the oil pump chain guide was not reinstalled when my motor was built.
Finding the guide itself online gas been no problem, but does anyone know the part numbers for the bolts that mount it?
Also discovered during the teardown that I only had two of friction washers on the crank snout. No washer between the cam sprocket and the oil pump sprocket. I'm amazed it made it 10k miles at 450+ hp before slipping.
