Jordan hopwood
Alright yeah I'll see how it all looks and I'll keep you updated for sureThat's good. I'm not trying to come off as an asshole in my post, just trying to explain the process of testing the circuit. I need to make a correction though to my previous post. There could be TWO power wires. One power wire is for injector 1 and 4, the other is for 2 and 3. Prodemand is what I am using as a wiring diagram reference and it shows two different schematics based on California and Federal Emissions. Let me know which yours falls under.
The injector resistance should be 1.0-1.2 ohms if testing the injector itself right at its connector. If you try to test injectors with their harness connected you will get a different reading due to the wires in the harness having resistance as well which will add to the reading.
Also just wondering but what grounds are the ones mounted on the passenger mount and under the mountAlright yeah I'll see how it all looks and I'll keep you updated for sure
