PlutoMs3
Alrighty. Plugs are regapped. Codes still persist. The P0302 code is still active and pending, but there is also P2088 code. I was reading about it, you guys are right, definitely not the sensors. So, what is the most likely culprit of P2088?
The oil control valve came up as a common problem, as well as a problem with the wiring of the connection to the sensor.
I did retime the engine myself during the rebuild, but that should have sent other codes relating to timing if that was the issue. Same with a problem with the battery or charging circuit. So, it seems like there is either a problem with the wiring or the oil control valve. Is that a reasonable assumption ?
