Joseph Conley
A little history since I am new around here. I just bought my first Mazdaspeed 3. I am totally new to Mazda. I was looking for a fun little car, that wasn't to low to the ground and easier to get in and out of. I found the car I bought down in Atlanta and seems to be rust free, and in decent shape, but didn't run. It was a 1 owner car with 191,000 miles that had been traded into a dealer and I was told it had been running when the dealer drove it home 1 night and was parked in his garage and never started again.
I bought it and trailered it back to Indiana. I charged the battery and started doing some basic troubleshooting. Through some sensor testing, I determined the crankshaft position sensor was bad. I replaced it and the car started right up, but was running rough. I scanned for codes and it had a fuel pressure to high code. Fuel pressure was reported at 2281PSI, and never changed even when the engine was shut off. I unplugged the fuel pressure sensor and tested signal on the wires and they were good, and then checked the sensor and it seemed good as well. I don't have a digital o-scope to really test to much,but it had resistance and was putting out a signal. I noticed the wire had been back probed and slightly damaged. I plugged it back in and suddenly the engine smoothed out and ran well.
I took it for a test drive and noticed every time I accelerated very hard the engine would cut out and go almost into what I am going to call a limp mode. It would stay running but with no power. If I pressed on the brake very suddenly it would start running well again. I accerated all the way close to redline very slowly winding the engine up, and it ran great, but any sudden hard acceleration would cause it to cut out most each time, but not every single time. I downloaded a free app I found mentioned on this site and ran it on my laptop and monitored the fuel pressure on the next test drive. Fuel pressure was around 400psi at idle, and then go up over 1000 while running it. I noticed each time it cut out, the fuel pressure would be at 1760psi.
The dealer asked me to give him a call and tell him what the problem was if I got it running. I called the dealer and gave him an update and he told me he had replaced the fuel pressure sensor trying to get it fixed to no avail. I decided he might had damaged the wires and thought maybe the wires were being pulled on when under heavy acceleration. So I ordered a new wire plug and replaced the bad section, but it didn't fix the problem. I ordered a new Bosch fuel pressure sensor as I am not certain of the brand he installed. I am waiting for it to come in, but thought I would ask for your thoughts of other things to check while waiting on the new sensor to come in.
