"Princess" A Mazda 323 like no other.
With that much spring in the rear, for such a lightweight car, plus the trailing arm with that wide poly bushing, how much passive steering do you plan to use?
You may not get that much flex, and not need to worry about it with this current set up.
The passive steer isn't coming from bushing flex. With heim joints and polly bushings, there isn't really any flex. The passive rear steer is a function of the arcs the lateral links and trailing arm move in and how it dynamically shifts things. My goal is to dial out the passive rear steer and hopefully make the car rotate better.
The increase in rear spring should allow me to run my rear shocks and rear bar on softer settings and give myself some adjust ability. I was running with the rear bar and shocks pretty much full stiff last year.
@phate i found you a friend
Yays.
Next up.. Bump steer. Using my laser level and work bench, I marked where the laser hit my bench. From there I cycled from full droop to full compression. Once done, that high school math you never thought I'd used comes into play. I measured the distance from the marks to the laser. Then measured the distance between the marks. From there you can math out how many degree of movement you have. In my case it's about 1.7 deg of toe change.. specifically toeing out. This makes sense, some toe out during bump is going to induce some understeer. Manufactures want a car to have more understeer characteristics for safety.
That's all for now. I've gotta come up with an excel sheet in order to track all of this.
Nice thread! Not many people go through the effort to measure all of this but it really helps in understanding where not to set things. Where to set things is forever a subject of debate and ever flawed data analysis (lol).
I will say that measuring bump steer like this can be done, but you have to account for scrub (change in lateral position of the wheel surface). You can severely influence bump steer curves when you don't. An alternative way to measure that cuts the error down by a factor of ~300:
Camber set aside lets look at a different aspect. The rear suspension of these cars is known to have what's called "passive rear steer". This means the rear tires turn slightly as the suspension moves. I've never measured this or looked closely at it. It's been assumed that it helps the car rotate when turning. It's also been theorized the bushings helped with this. Non of that is the case. As the suspension moves up, the trailing arm moves through an arc that pushes the knuckle backwards slightly. This shifts the lateral link alignment, causing the rear to toe in for more stability. I have a plan to relocate the front of the trailing arm with the hopes of eliminating this.
I am running into another problem. It's the reason why I don't like Poly bushings. In order to get rear camber I have tilt the knuckle in. When doing this it twists the trailing arm. Well the bushings don't like this. It's causing them to bind up. For this season it is what it is, but in the future I've got to find a way to get a spherical bearing in the front to allow the arm to twist and move smoothly.
For the passive steer in the rear, it's worth considering what happens when the system sees that lateral load and how different bushings stiffness can influence that behavior. It comes from both geometry changes and bushing deflection. It may do something in the air on stands that could be changed drastically with some bushing deflection.
On the trailing arm side of things - what does that forward mount look like? I converted to sphericals several years ago in the 6 and did this for the trailing arm:
Yays.
Thank you for that video. I haven't see bump steer measured that way before. I'll have to try it and compare my results. All though I am in the process of screwing up all my testing data. I have some spherical bearings to install in the front control arms. These came off my old SMF car. I've got adjustment in the rear bracket, plus the rear bushing being off set, and some planned modifications to the front control arms, I am hoping to gain another 3 deg of castor.
The front bushing for the trailing arm will be fairly easy to convert to a spherical bearing. I just need a friend with a lathe and some time.
With heim joints in my lateral links the only bushing flex I have is the poly bushings in the trailing arms. A long time ago I took a video of my rear suspension during an autocross run. I don't remember seeing anything going on that makes me worried about bushing flex in the trailing arms.
The issue I do have with the trailing arm is trying to get camber. The upper bolt is slotted for camber. This twists the trailing arm as the bottom mount moves outwards. As we know, polly bushings hate being misaligned. 20260411_204748 copy.jpg
I wish I had a CNC machine or mill. I've got a custom throttle body adapter to build in order to make an ND2 throttle body fit. This will give me a proper IAC valve. I wont have to fight with tuning around the stock coolant controled high idle valve and "Idle up" valve that's not really designed to be modulated by a stand alone ECU. All though you can do it and it works. I've found cold start tuning tricky to get right. You can't really anticipate the high idle valve and how quickly it closes and when you need the idle up valve to start taking over.
Shameless plug here - I make custom parts and focus on the racing community for projects like this. I've made some pretty nutso complicated TB adapters with bent passages and ORB ports and whatnot, and I've even made some IAC housings recently. Prototypes, one-offs, and small runs of parts are what I do.
I had a thread like this on MSF (rip) with all the suspension data for the MS6. I also went through spring and bar math for setting up a car by the numbers, and replicated that over here when MSO went live. Link.
My MS6 has been in ESP for ~10 years now. We (my wife and I) campaigned it nationally with pretty good success. I've been 2nd at nationals in ESP once or twice, won several tours, and indexed as high as 11th at nationals. We took last year off since we had a baby, but should be back out at some point this year if things go well.
I appreciate the offer. I've been slowly learning how to do 3d modelling in order to have a file that I could send to someone like yourself. I am not there yet but I'll keep you mind when I do. I remember hearing about your early success and started following what you were doing quite a while ago. I appreciate having you coming in and passing along some of your thoughts and knowledge. I read through your thread a long time ago, a lot of it was way over my head back then. I am starting to grasp more of it now.
Justin Brabry did an extensive FSP build back in the day on a Protege. It's been retired from autocross to track duty. I used a lot of what he was doing as a frame work 10+ years ago.
It's interesting when you talk about roll bias, This has been talked about as front and rear roll stiffness to me. Despite some of the math I've been doing with tuning my Speed 6, doing motion ratio calculations, sway bar calculations ect is a bit beyond me for now. I think I understand most of the concepts.
For anyone interested. He's a fun video of the LF suspension and tire in action. If you watch it close enough you'll see the front control arm mounting point flexing. That's the sub frame flexing, not bushing flex. I had the solid spherical bearings previously posted installed at that point. This car eventually got a 2 point brace to help fix that. Princess has a 4 point brace.
Another old video. This one is the rear suspension. I have the same lateral links with heim joints here. But I am running stock trailing arm bushings. You don't get a good shot of what the trailing arm is doing. If it's flexing back and forth. but it's a fun video to watch. Plus both videos you get to hear the glorious sounds a 2.5L KL V6 makes as it's revving out. The 1.8L V6 versions in the Mx3 were known for the amazing exhaust sounds.
Just because its poorly executed, home made from scraps, without a plan, measurements or even a ruler. Doesn't mean it was a stupid idea..
I present to you a Camber adjustment tool, for those of us stupid enough to try and do things the hard way.
If you are looking at this scratching your head wondering what kinda stuff I have been smoking. Let's take a little step back, you'll realize it's even worse considering I was sober while creating this monstrosity
The upper bolt holes on the strut are slotted. This allows the knuckle to pivot on the lower bolt, tilting the wheel in and out adjusting camber.
the problem with this method is adjusting things when the weight of the vehicle is on the suspension.. It's forcing the knuckle to tilt inwards as much as possible. There's a lot of force fighting against you trying to make this adjustment.
Based on an OTC tool for adjusting older GM's with slotted struts, I came up with this monstrosity. It hooks into the knuckle and pushes against the strut body. This tilts the knuckle out allowing me to adjust the camber accurately with the car at ride height and weight on the suspension. Once the desired camber is reached. I tighten down the bolts and we are good to go.
Some of you might ask.. why don't I just used camber bolts instead of slotting the struts? Simple, I tried... They don't provide enough adjustment for what I need...
Setting up coil overs and doing a custom alignment takes a lot of time. Time I was running out of this week. The car needed to be road worthy for this Saturday. I had committed to putting the car in Tuner Bash's opening event. This is a Car show series with some drifting and drag racing. Overall it's good times. A close friend of mine is part of the crew that helps put the local show together and does some of the media work. This year was a little more special as I got to enjoy it, not only with my kiddo but a few other local Mazda Econobox enthusiast.
If you know what you're looking at, the bone stock white sedan next to the Mx3 would be the special car this line up. It's an all original 89 323 GT with 100,000 kms on it. The 323 GT is the Turbo fwd cousin to the Rally homologated GTX. North America got this car for 88 and 89 only. With lower sales numbers then a GTX (some where between 800-1000) this is an unknown jewel. This perticular car is a bit of a unicorn. It had been optioned with electronic adjustable suspension that still works!
Trust me, this is the kinda stuff to geek out on.... Or maybe I am just getting old..
Friday at 5:30pm I washed the car and realized it was in ruff shape. I also remembered, that I had not road tested since redoing all of the suspension and it didn't have any insurance on it. Sooooo an hour later I took my first drive around the block. During which I relized the wheels hadn't been properly torqued, the rear control arm lock nuts hadn't been tightened down, and intake wasn't tightened down. No big deal.... at 2:30 am I left the shop to get some rest. 8:30am I was back at the shop to finish a couple things and help kiddo get ready. Considering all the last min prep, the car looked great.
It even brought home some hardware for the 2nd year in a row.
So what do you do after a scramble to put a car together for a show?
You bring it home a tear it apart again... :rolleyes::rolleyes:
This time around it's more track prep and winter project stuff that I wasn't able to get done. One of the new goodies I installed was a RaceCapture Pro MK3. I haven't installed any sensors yet, but I do plan to add oil pressure, Steering wheel position, Brake pressure, AFR. I am also going to add a MAP signal in order to replace TPS.. The electronics on this era of car is a bit archaic. The stock TPS sensor is a 3 position switch, rather then a potentiometer. Since Manifold vacuum corrolates with throttle position, this is the next best thing.
The second thing I installed is a guage pod with some fancy new guages . Rob designed and built this pod 10 years ago. He spent many hours getting the positioning just right so that the other gauges were still readable.20260505_223011.jpg
Looks like when I posted this, I forgot to finish it. Oops. Not to self, stop doing stuff like this before bed.
Under the hood you might notice a shinny knew intake pipe, replacing the old stock one. I did this partially because I just wanted to, the other reason was to aid in adding catch cans to the car. Looking at pictures from being out on track last year I noticed quite a few had smoke out the tail pipe. I don't have reason to believe this is a motor issue. The rebuild done on the motor is still relatively fresh.
The intake I built may or may not be hurting performance. Have you ever noticed weird chambers that stick out on the stock intakes? These are referred to has Helmholtz resonators. Not only do they quiet down the fun intake sounds, but they are part of how and engine makes power. Admittedly I didn't know this. A friend mentioned something about it to me after sending him pictures. I've swallowed the coolaid thinking stock intakes are restrictive and upgrading is a way of making more power. For the most part this it true on old stuff like this, but in the Miata world that wasn't the case. The resonators on a1.6L NA miata help prevent a dip in torque around 4000 rpm. When it comes to the 1.8L NB's this might not be as big of a deal. It's hard to find proper information on this since some of this stuff would be trade secrets in the spec Miata world. All though this BP is in essance a miata motor, dyno testing and research hasn't been done. So it's one of those things. Have I made power? Or reduced it? At the end of the day it's sure pretty and my aluminum welding is slowly getting better. If I can get funds together for some dyno time, I might do some of my own testing.
20260505_221140.jpg20260505_221126.jpgoriginal_78e40963-ef46-4fe9-aefa-92671fb5a5a4_20260504_190824.jpg
Huston we have a problem. Wellllll ok I wish I was still ignorant to this problem..
Lets back up a little bit. I left things off with tearing apart the car, installing a Racecapture Pro 3 data logging system while I was waiting on some new 225/45R15 Vitour P1 X-01Rs. Well the Vitours fell through. Supply chain issues due to some kinda war caused issues with the ability to get raw materials. Thankfully I was able to back out of the group buy and picked up a set of 205/50R15 Bridgestone RE71RZ's.
Now back to the problem at hand. With a data logger come's the ability to see what's going on with things like.... lets say oil pressure... Yeah, I've been racing all this time with out knowing oil pressure was dropping off during decel. NOT GOOD! not good at all.. So what am I going to do about it? Well.. until I get time to pull the oil pan off and look at baffling, there wont be any Time Trial events for me. Autocross events will go a head as planned.
Some highlights from last weekends event. A meeting of minds while prepping for the first morning runs.
704827570_10163085940296492_3746681130051437875_n.jpg20260523-IMGP1681.jpg20260523-IMGP1547.jpg
Action shots.
Princess and I finished 13 out of 91 Drivers. The car really needs some new coil overs, but over all she feels fantastic.
A couple of videos for your viewing pleasure.
First up my morning run. A great perspective when it comes to good steering wheel control.
Next up. My quickest run of the day.
