Product Idea
cshunter
I would like to see a OCC/Coolant tank.
In short, it's a tank diveded into two parts. Half occ, half coolant tank. Since y'all also do our pmm, y'all would be able to easily see if this is something that can work.
Why would this be a good thing? Well a fair amount of bt/built motor people tap the valve cover for an lines to occ's, could make for easy or clean routing of lines, also no one currently produces a different coolant tank.
As for features:
1. Works with y'alls PMM
2. Works with stock or other PMM
3. Somehow easily or convieantly drain able for the OCC.
4. Sight glass for Coolant tank
Pics for references.
PS. Don't mind the sticker there, I didn't put it there and need to replace it :)
Sent from my Pixel using Tapatalk
The Valve cover line could just go to a large catch can, I'm not seeing what putting it next to the coolant gains you. To that point, I'm not sure what the purpose of an aftermarket coolant tank would be in it's own right.
Believe the idea is to better utilize the available space on the passenger side. So after market coolant tank is secondary to having a catch can (fed by weld on bungs) that fits within the area above the passenger side frame rail.
Other than aesthetics, I'm not sure either. I think it's a convieant idea to have something like that to keep things tidier and another way to do things. That's really about it.
We have made custom kits in the past that go in the back behind the alternator, and I've long thought of making a larger catch can for big horsepower applications. Might be time to make that a kit for those wanting valve cover venting.
Browsing FB today, saw this. Really not a bad idea.
