Year/Make/Model: 2008 Mazdaspeed3
Mileage: 160K chassis / <1K motor
Concern: Radiator fan not turning on most times.
DTC's: None
Modifications: BNR S3v4, catless downpipe, CS internals, 3in intake, FMIC, etc
ECU/Tuning Software: Accessport V3
Tuner: DramaTuned
Is the concern intermittent? Yes
Recent Repairs: Nothing fan related
Correction: N/A
Another day, another issue! This one could be an issue I've been dealing with for years now that I really think about it. It's 70-80 degrees F here and lately I've been seeing my coolant temps exceed 219 when not moving. This is typical in the middle of summer here, but not toward the end of winter.
I'd park the car and pop the hood and the fan would not be running most times. One time I actually saw it kick on and turn off again moments later, with the temps still at 228. I knew something was going on with the system, but the fan itself spins fine and freely.
So I got to troubleshooting:
DTC's: None
Tuner: DramaTuned
Correction: N/A
- B+ power to the fan connector
- Ground is solid to the fan connector
- Continuity between signal wire in fan connector and PCM connector
- Manually applying B+ voltage to the wires at the fan, after the module, turns the fan on full tilt no issues.
