Carter Johnson
Hearing a tiny bit of rear diff whine at approximately 58-61 miles an hour. Below 58 it’s silent, above 61 it’s silent. The only time you car hear it is while on the gas going 58-61 miles an hour. It’s not necessarily loud but I can definitely hear it over my 3 inch exhaust if I have the music down. Is this something I should be concerned about? Car is lowered and I know that can sometimes change vibration noises and such but don’t think that would cause this
On a side note also getting some ticking noise when accelerating, usually only for the first 1000 rpms of 2nd gear but sometimes when just coasting. I got under the car and shook the drive shaft around and it seems solid, transfer case mounts could be shot though, hard to tell. It sounds like it’s coming from right under the trans tunnel. You can’t feel it in any way, you can just hear it
