I didn't have my flywheel yet or I would've
Inspect the current parts and save money where you can.Ok thanks
I had been considering just using the existing flywheel and clutch etc. but then wasn’t sure when I was reading about balancing. The reason I was considering is that the clutch felt very good and the pedal was fairly heavy (not quite like a daily driver) and I wondered if the previous owner replaced it with a quality clutch kit (there were several other upgrades). And the motor had been replaced with a used motor less than a year before I bought it. So ... perhaps the clutch was replaced then. I’ll see once it’s all apart. But of course if I have it all apart I might as well start fresh, but saving money sounds good.
I would not reuse themI ended up just taking it apart. Of course I needed to to get the crank out, but I’ll bring the piece and see what they say.
Are those 10 bolts torque to yield?
if you're gonna do it. do it right. i would not use stock pistons with forged h beam rods, i would have to add the forged pistons.
Can someone recommend bearings?
For the rods and also the similar looking but larger bearings for the crankshaft. (Not sure what those are called.)
I contacted EdgeAutoSport about piston rings and bearings.
Firstly, they said to ask the machine shop what size bearings to get (they also recommended King). Is there not a standard size for the Mazdaspeed?
Secondly, they said the rings for the Manley Platinum come a certain size and that I can’t specify what I want. So I’m assuming I’d need to order more rings separately with the 0.02 and 0.022 sizes?
Thanks.
