PMs are tied behind post count, keeps the spam messages out you'll be able to do it soon enough![]()
I figured. It's time to activate my chatterbox powers!
There wasn't an option to DM you, so I thought I'd ask here.
Is the machine shop you went to any good? I'm in the Bristol area and I was looking for a machine shop so that I can get work done on my block for my build. How expensive were they? Do you recommend any other shops?
I use two machine shops. If you’re wanting quality machining I’d recommended L&M Engines in Hatboro, PA. They seem like an overall good shop. https://lmengines.com/
I also use ECAM in Glenside because he’s closer to me. He’s a nice guy and has done me some favours, though honestly his machining on my cylinder head was not very good and I had to take it to L&M. But he knows engines and does other things well (for instance he resurfaced by DMF with no issues, or getting the ridiculous phaser bolt out of my Audi’s exhaust cam, etc.).
After the holidays I'll give them a ring and see how much this is going to run me. I hope they don't burn too much of a hole in my pocket! Are there any other shops in the local area that you recommend to do work on your car? Ideally I'd like to build the block myself, but if I mess something up I'd like to have an expert do it before I waste thousands trying to fix it myself.
