DTB
Thought I'd randomly and quickly review this piece. I ordered this flywheel with the Luk clutch kit from EdgeAuto. No complaints on shipping or Edge - the shop that did the job claimed I was missing a few of the bolts or small stuff but since I no longer deal with that shop, fuck 'em.
The only thing I really wanted to say was, I actually miss the heavy OE dual mass flywheel. If it only wasnt $1200 CAD lols.
I'm still unsure if the main difference was more to do with almost 9 years on the DMF and the Fidanza is just broken in (3,000~ km or 2 months) but it is so damn light. I thought that'd be a good thing but panic clutching/shifting makes me think my foots going through the floor and I've already cracked the firewall from the clutch pedal once already (different story there).
Perhaps it just doesnt feel as solid because it requires much less leg pressure to depress because it obviously works. It just drastically changes the feel of the pedal. Almost to the point where you think a spring is in backwards.
Note on the green coating and installation: due to my previous clutch pedal/firewall issues, the tech had to scrub the green stuff off. After looking at the pictures of the flywheel, it looked like the green coating is on a removable plate or disc held by some screws. That issue was probably unique to my car since my firewall has an extra brace which probably extended the cable past the usable point. The issue was the clutch stayed open and they couldnt release it without removing the green coating. Or that was part of the story and the ride they took me on.
So if this flywheel lasts as long as my new short block and accompanying rebuild, zero complaints. But it has to live up to the stock clutch/flywheel which was a beast as I launched my DD daily with a canned tune (hypertech) on a stock turbo and then some for 274,000km and it didnt complain.
