Malevolous
New to the Mazdaspeed scene, but not the Mazda 6 platform!
I've had my 05 Mazda 6s v6 since '09 and was around the 6crew and 6club forums during those years. Always wanted a Speed6, seeing how much easier they were to mod. Found this 95% rust-free 2007 MS6 in Velocity Red with an Overspeed engine for sale in PA for $7K and thought that was a pretty good deal. Only known issue was a P0507 and a 2nd gear pop-out on decel. The first oil change turned into a year of maintenance, replacements, and upgrades - none of which could be spaced out. From Feb '23 to June '24 everything below has been done.
What it came with:
- Overspeed built engine (80k miles) with 144k miles on everything else
(ARP Headstuds, CP Pistons, Crower Valve Springs, Manley H-Beam Rods, Keyed Crankshaft)
- Garrett GTX3071
- Front Mounted Emusa Intercooler
- South Bend Stage 3 Clutch/Flywheel
- AWR Trans Mount (? Duro)
- Corksport Rear Differential Mount
- Corksport Rear Engine Mount
- Corksport Rear Strut Brace
- Corksport Rear Shock Brace
- JBR Passenger Side Engine Mount
- Autotech HPFP
- EGR/VTCS Deleted
- Tial Q-11R BOV (Probably Knock-Off)
- Blow-Through MAF Setup
- Emusa Wastegate
- CP-e Exhaust Manifold
- M2 Performance 3" Downpipe
- Speed Performance 6th Port Injection Kit
- ISC Coilovers
- SPC Ball Joints
- Battery Relocated to Trunk
What went into it:
- Damond Triple Engine/Trans Mounts (Street)
- Damond Power Steering Cooler (Small)
- Rebuilt PS Pump OEM Internals
- Damond Brake Caliper Bushings
- Damond Stage 3 Catch Can Kit
- Turbosmart GenV RacePort BOV
- Turbosmart GenV CompGate40 EWG
- New OEM Coils
- Racethetix AC Line Tuck
- MSWT Full Wire Tuck
- N2MB WOTBox
- Rey's Custom Shift Cables
- Corksport Throttle Body
- Corksport Intake Manifold
- Corksport PI Rail
- ID1050x Injectors
- Split Second Injector Controller
- SP63 Cleaned/Flowed Injectors
- Overspeed Injector Seals
- Koyorad Aluminum Radiator
- Innovate Motorsports Powersafe Boost/AFR Gauge
- New OEM Passenger Axle
- BC Coilovers w/ Swift Spring Upgrade (Front)
- Trunk Battery Circuit Breaker
- Upgraded/Added Grounding Cables
- Custom-Fabbed Underhood Electrical BusBar Mount
- Eaton BusBar Electrical Distribution
- Every SINGLE Trunk Seal/Gasket to finally fix the damn leak
- Bunch of other exterior/interior/aesthetic mods to list later...
Future Mods List
- Damond Front LSD (Just waiting to install)
- T-Case Rebuild & Caps
- Rebuild Trans/Synchros/Forks/Whatever is making 2nd pop out
- Russian Control Arm Bushings
- RacingBeat Sway bars (F+R)
- Adjustable Endlinks (F+R)
- Repaint Soul Crystal Red
- More to come
What it came with:
- Garrett GTX3071
- Autotech HPFP
- EGR/VTCS Deleted
- Emusa Wastegate
- ISC Coilovers
- SPC Ball Joints
What went into it:
- New OEM Coils
- N2MB WOTBox
- Corksport PI Rail
- ID1050x Injectors
Future Mods List
- More to come
