modusoperandi
An update, had the package overnighted to me & the part was the correct one this time. Went through a rough time properly getting the new one installed & getting the old one removed. Apparently Mazda decided it was a bright idea to place a bracket against the firewall right where the turbo is located. The nut was basically stuck there from the constant heat it receives from the turbo. At one point I said screw it & sprayed Liquid Wrench in the area to get the nut off. Drove the car & the shifting feels better than it did before the whole problem with shifting. The old cable had its years of use that I'm sure it must have stretched out over all of the time. I'm glad it wasn't something else causing the shifting problem.
Edit: Mods please close thread. @NavysailorMS3
