Welp, looks like it's time for new Hpfp internals. Seeing pressure drop to ~500psi right at peak tq rpm for a cell or two (~5300rpm), before going back up, and also in low load situations out of boost around 4k; even after cleaning up the sticky death that I thought was causing it.
The autotechs in the car, I bought used off the other forum back in spring 2013, and I've put roughly another 175k on em, so I can't really say I'm surprised lol. At least I got my monies worth!
Back when I was running E23, 5858 and stock block, 22psi; roughly a 10% decrease in IDCOut of curiosity, how much extra fuel does the 2150 psi relief valve allow your car to flow?
My tuna is targeting 2056psi in certain loads. Keep in mind these upgraded relief valves cause fuel cut in high rpm on 95% of the cars they were tried on, and cost $400. So that's a pretty expensive experiment that may not even work. I lucked out and found one used on msf for dirt cheap, so we tried it. Most tuners will tell you not to bother.That's very impressive. In that case I will probably pick one up and experiment with it. Have you altered your fueling tables at all?
I saw one for sale not long ago for a pretty reasonable price. If your tuner found a way to make it work, I'm sure I can, too. Are you on Versatune, or Cobb?
That Circular plate with the 3 bolts is supposed to be below the lca with the perch above the lca seated in the spring, Lmao. Holy Buddha was I pissed when I saw that. Dropped the control arm down to unfuck it all and got it all oriented the way it should be. But the fucking threads on the adjustment are fucked, so I can't raise the rear up....many curse words were said. So now to figure out if KW will sell just the perch so I can unfuck my rear suspension. Crazy thing is it never made any noise back there, so I never really looked. But that's what I get for trusting people...
