rang-a-stang
Silver Member
Doing tuning for my down pipe and Tuner noticed my fuel rail pressures are low. I have been watching them for the last week and they are low and kind of all over the place. Idle is about 450-600. Cruising on the highway is about 1500. If am idling (about 450-600psi) and I blip the throttle, pressure goes to 1500-1750. WOT is MAYBE 1600 but it kinda jumps around.
Background: Once tuner noticed pressure was low, he recommended I pull/clean HPFP... so I did. I found a nice clean and spotless HPFP (including the internals). I saw no abnormal wear. I just cleaned my HPFP and installed all new O-Rings. I pulled my dump valve and it was spotless. Car runs OK. It does miss/surge some at WOT. No CEL at all. LTFT is kind of all over the place between 4 and 12
Should I suspect my PRV? My fuel pressure sensor? Could it be the little filter on the rail?
