Parts
SUBWOOFER
PIONEER TS-SW3002S4 12" 1,500-Watt Shallow-Mount Subwoofer with Single 4ohm Voice Coil
Link:
http://a.co/28EabN7
SUBWOOFER BOX
Bbox Single Hatchback Sealed
Link:
http://a.co/bXXzrg3
DASH KIT
Metra Double Din Installation Dash Kit for 2004-2009 Mazda 3 Install Kit
by Metra
Link:
http://a.co/aggf6SG
STEERING WHEEL CONTROLS
Metra Axxess Universal Steering Wheel Control Interface
by Axxess
Link:
http://a.co/241DGnJ
DECK
JVC KW-M740BT Apple CarPlay, Android Auto 2-DIN AV Receiver (No CD Drive)
by JVC
Link:
http://a.co/8SdQk0n
HARNESS
Metra Electronics Wiring Harness for 2001-Up Mazda Vehicles
by Metra
Link:
http://a.co/enVAS1e
DOOR PANEL CLIPS
50xNylon Interior Trim Panel Fastener Clips for Mazda GJ6A-68-AB1 G350-68-AB1
by ACD.Clip
Link:
http://a.co/d0OxRQ7
AMP WIRE FERRULES
Baomain AWG 4 / 25mm² Long: 20?.787?mm Wire Copper Crimp Connector Non Insulated Ferrule Pin Cord End Terminal 50pcs
Baomain
Link:
http://a.co/6TLr604
Baomain AWG 2 / 35mm² Long: 25mm Wire Copper Crimp Connector Non Insulated Ferrule Pin Cord End Terminal 25pcs
Baomain
Link:
http://a.co/1zxDwr0
AMP WIRE LUGS
SELTERM UL Listed Marine Grade Heavy Duty Tinned Copper Lugs
by SELTERM
Link:
http://a.co/0R1BKCM
by SELTERM
Link:
http://a.co/0UjWd4i
MLV
TMS Mass Loaded Vinyl 4' X 10' (40 sf) 1 Lb MLV Soundproofing Barrier. Highest Quality!
by Trademark Soundproofing
Link:
http://a.co/fW2sOGf
WIRE GROMMETS
InstallGear 180pc Rubber Grommet Assortment Kit - 1/4", 5/16", 3/8", 7/16", 1/2", 5/8", 7/8", 1"
by InstallGear
Link:
http://a.co/fRRKdQz
AMP RCA WIRES
Rockville Apm10b 10" 400W Powered/Active Studio Subwoofer Pro Reference Sub
by Rockville
Link:
http://a.co/bk7cYN1
by Rockville
Link:
http://a.co/4jIkgPm
SPEAKER WIRE
MaxBrite 14AWG, 2-Conductor, Speaker Cable
by MaxBrite
Link:
http://a.co/hiK8PgH
SPEAKER RINGS
FAST Rings 5x7" 3-Piece Car Speaker Enhancement Kit
by FASTRings
Link:
http://a.co/9MKABX1
FAST Rings 6.5" 3-Piece Car Speaker Enhancement Kit
by FASTRings
Link:
http://a.co/9K0qW2B
WIRE TAPE - CLOTH QUIET
Tesa 51608, 25m x 19mm adhesive wiring cloth tape original ISOBAND 3 pcs pack
by Tesa
Link:
http://a.co/622l9IU
AMP WIRE
Welding Battery Pure Copper Flexible Cable Wire -- Car, Inverter, RV, Solar
by WindyNation
Link:
http://a.co/fj88a8u
by WindyNation
Link:
http://a.co/2UtOSav
SPEAKERS
SKAR - TX65C | 6.5" 200 Watt Elite Component Car Speakers
https://www.skaraudio.com/products/tx65c
SKAR - TX68 | 6" x 8" 200 Watt Elite Coaxial Car Speakers - Pair
https://www.skaraudio.com/products/tx68
AMPLIFIERS
Hifonics ZXX-600.4 Zeus 4 Channel Bridgeable Amplifier
Link:
http://a.co/iXZGkeT
Hifonics ZRX1216.1D Zeus Mono Class-D Subwoofer Amplifier, 1200-Watt
Link:
http://a.co/98JvxcA
DEADNER
Kilmat 80 mil 36 sqft Car Sound Deadening Mat, butyl automotive Sound Deadener, audio Noise Insulation and dampening
by Kilmat
Link:
http://a.co/dkyPgsB
Speaker Adapter - Front Door
Universal 5x7 or 6x8 to 6 1/2" PVC Speaker Adaptor 6mm (X-LARGE 5.75" Cutout)
https://www.ebay.com/itm/Universal-5x7-or-6x8-to-6-1-2-PVC-Speaker-Adaptor-6mm-X-LARGE-5-75-Cutout/301657169309?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Distribution Block
InstallGear Power Distribution Block
by InstallGear
Link:
http://a.co/hpSOQYj
De-Coupler
Reflectix 50-sq ft Reflective Roll Insulation (24-in W x 25-ft L)
https://www.lowes.com/pd/Reflectix-50-sq-ft-Reflective-Roll-Insulation-24-in-W-x-25-ft-L/3011904
HVAC Tape - works well for contours and keeping things in place
Growneer Aluminum Foil Tape 2 Inch x 150 Feet, 3.4 Mil HVAC Tape, for Ducts Repair and Sealing
by GROWNEER
Link:
http://a.co/49jKRlE
[doublepost=1527261041][/doublepost]I am posting the imgur album and will add notes as I can. If you have any questions let me know. As I think of things I will add them.
SUB UPDATE 6/13/18
I ended up going with a low profile sub box as I could no longer wait to do fiberglass and see the sub just sit there. If I decide to fiberglass I will update this thread. I am really happy with the bass. It is not super crazy but it is more than enough for the small car. It fills in where I need it and gives that nice kick. I was able to take a little stress off the door speakers and move it to the sub for a better blend.
imgur.com/a/Bas6Gqd
