This is a database for spark plugs which have a heat range of stock / 1 / 2 stages colder than stock. If I'm missing anything let me know and I'll update
MSO Spark Plug Database
Gap size: 0.024-0.027" (or smaller where required)
for you those who gap in mm:
0.60-0.70mm
Type and Specs on DISI 2.3L Spark Plugs:
14mm; 5/8 hex; 25mm reach; projected tip; resistor plug
Heat Range Conversion Chart
HKS 25 30 35 40 45 50 52.5 55
DENSO 16 20 22 24 27 31 32 34
NGK 5 6 7 8 9 10 10.5 11
Spark Plug Manf & Part Numbers
Denso Iridium
- itv-20: Stock heat range
- itv-22: 1 stage colder heat range
- itv-24: 2 stage colder heat range
- itv-27: 3.5 stage colder heat range
NGK IX Iridium
- NGK SILTR6A7G (95369) Stock Heat Range - Gen2 OEM Part 0.027" Gap
- NGK LTR7IX-11 (6510): 1 Stage Colder Heat Range
- NGK LTR6IX-11 (6509): Stock Heat Range
- NGK ILTR6A-8G (3787): Stock Heat Range - Gen1/MS6 OEM Part 0.032" Gap
NGK Ruthenium HX
- NGK LTR6BHX (90495) Stock Heat Range
HKS
- 50003-M35LF 'Mazda MZR Engine': Mazda 3, Mazda 6, MX-5 '06 7 $22.97ea. - 1 Stage Colder Heat Range
- 50003-M40LF 'Mazda MZR Engine': Mazda 3, Mazda 6, MX-5 '06 8 $22.97ea. - 2 Stage Colder Heat Range
Torque Master Spark Plugs
- SVTP8BR: Stock Heat Range
- SVTP7YR: 1 Stage Colder Heat Range
Autolite Iridium
- Autolite Iridiums XP5364: Stock Heatrange
- Autolite Iridiums XP5263:1 Step Colder
Copper Plugs
NGK Copper Plugs
- LZTR4A-11 (5306)
- LZTR5A-13 (4306)
- BKR7E
