SPEED 3 awd conversion
Well the car now has another new owner, located somewhere else in ohio, sad to see it go but hope the next person uses it more, best of luck little car
New owner of the AWD Speed 3 here, I’ll also update my progress with this car here if that’s allowed. Currently is only running 14psi on the bnr s3 turbo with dual 400 pumps. Could use a front lsd tbh, spins the front wheels. Not sure what the center differential controller settings do but I’ve been trying them out and some put more power to the rear which noticeably limits front wheel spin. Not a fan of the fuel tank in the trunk so ill be looking into relocating it - most likely using the volvo s40 tank that supposedly works. The rear sways back an forth especially at speed and in wet conditions so Ill be getting an alignment soon and post an update as well. Its a fun car, definitely ligher than my dads speed 6 but the speed 6 definitely feels better sorted. For now.
AWESOME! Glad you are here! I am sure it will be great once you get it sorted.
