I'm back again...
Still having a few issues with my build, looks like maybe a pcv issue this time, to get to it the intake has to come out once more, it's a real pita to get out as the tb is facing 180 degrees away from where I want (need) it to be.
All aftermarket intakes I have seen, due to the platform the engine was designed for still have the tb facing the wrong way, however even though I had read the intake performance comparison thread a couple of times did not realise the st tb was facing down...
I'm assuming this it the 2.0p focus at intake?
I did a search here but the results showed all intake thread not just at ones
Couple of things, first is there detailed information on the st intake, the comparison mentioned an adapter, I'm assuming this will be just for the runners to the head.
I also have read a few warnings about just swapping out intakes without any other mods, that the engine could start running lean.
At this point I'm not after big power, it's going to be a daily drive, just looking at making maintenance easier.
I also considered making the intake run adapter for the mx5 mk3 intake as that's the car its in with the tb facing the way I need it, trying the keep it stock this far so to avoid tuning seems to be getting me nowhere fast, AFAIK the mx5 is somewhat similar to the stock oe intake, got long/short runner and the cold start flaps (can't remember the actual name for them) the adapter is somewhat trivial for myself it's a 100mm runner and can make them to mate up.
Using the st or mx5 intake without tuning will this run into potential lean situation, any advice on tuning, at this point I'm considering versatune and learning up on efi tuning
