Enki
Moderator
There absolutely is a VVT position PID. This could also potentially be just an especially loose VVT solenoid that can't run well at idle due to lower oil pressure.
Also, If you are on gas or the RPM is not coming down to idle, the rail pressure should always be above 400. If you are WOT and it drops, that's going to be an issue; no need to look at logs to determine that it's an issue.
