guitarcal
Hi all, could use some help. 2006 Mazdaspeed 6, air intake upgrade, Cobb stage 1 tune.
Yesterday, the car started stuttering under load and threw a P0301 code. As the car warmed up, it got better, but still a noticeable studder on easy acceleration. Spark plugs had 90,000 miles on them, so changed those first, but did not solve my problem. The pulled spark plugs looked good, cylinder 1 maybe had slightly more build up than the other 3 but nothing out of the ordinary
I've swapped coil pack 1 and 4 as the next test, but wanted to upload my accessport logs to see if the experts see anything here. I kept it easy, but there was noticeable studder around the 2000k rpm range.
Any thoughts? If I get an error code on cylinder 4 now, do I need to stick with oem coil packs, or can I go aftermarket?
Thanks!
Thanks!
