SpeedyThrees
Performance degraded rapidly from running perfectly, then stumbling, then barely running, then stalls, then starts but barely running, to barely starts, then to no start.
Back story.
2012 Speed3 - all stock except for junky Corksport Cold air intake and Catback exhaust
Car sat for 2 years with burned cylinder head.
Replaced cylinder head, timing and injector seals.
Initially had a no start problem that turns out was just simply stupidity. Link here, https://mazdaspeeds.org/index.php?threads/new-head-no-start-runs-on-starter-fluid.17540/
Stupidity resolved, car ran like a top on the jack stands under front only. I mean, balance a nickel on it smooth.
Took car for 5 mile test drive, ran flawlessly, then within 30 seconds went from stumbling to barely running, to stall.
Car sat for a couple hours, started up and ran just fine. Took for test drive, went 1/2 mile then the same degradation into stumbling, barely running, stalling. Each restart attempt yielded less and less willingness to stay running and eventually no start.
Car sat for 30 mins, started but running rough. Drove 1/2 mile home.
Car remained idling roughly in the driveway but with loud clacking and squealing from HPFP area.
Code reader showed only P0300 and approx 1000-1400 psi at fuel rail at 2k rpm.
Suspected HPFP failure, replaced with known good one. Inspection of cam cup, cam lobe and internals of removed HPFP showed no damage.
Start engine, idles very roughly but no clacking or sqealing.
Suspect water in fuel. Follow me here. Car sat in driveway for 2 years, plenty of time for condensation to build up. After rebuild, while on jack stands under the front, removed as much fuel as I could via HPFP inlet and cycling the fuel pump. Replaced 5 gallons of fresh 93. My theory is that when car was on stands, the water moved to the back of the tank and was not removed by the fuel pump. Then with car on level ground, the 5 mile test drive was enough to for the fuel pump to pick up the water and deliver to the engine causing my issues.
Fuel sample taken, 12 oz from HPFP inlet. Water in fuel confirmed. Approx 1/2 ounce in 12 oz of fuel. Add a bottle of water remover to fuel tank, shake vigorously. Cycle fuel pump until fuel samples at HPFP inlet are clear.
No Start, just a few putt putts. Suspect water still in fuel rail. Remove rail pressure sensor. Cycle HPFP to pump clear fuel trough the rail. Replace sensor. No start, just a single putt. Code reader now shows 0 psi in rail during starting attempts
Current status
New head and timing, approx 175psi all 4 cylinders
New injector seals, new OEM spark plugs at .027, fresh fuel.
60 PSI at HPFP inlet. Known good HPFP
Brand new battery supported with autoshop level battery charger with Starting boost
NO START, Just a single putt on every attempt.
Fuel rail pressure shows 0 psi during start attempts.
Only have a decent code reader, No access port or high end diag tool.
Suspected MAF damaged from starting fluid use after initial rebuild. Disconnected MAF, no start.
Suspect failed Pressure relief valve.
New MAF ordered.
Mazda will not sell me a new relief valve. Says that that part says not serviceable and only available as complete fuel rail unit. $1,000. haha.
Market is rife with pressure relief valves, but I've read so much conflicting info on which part number to get, not sure what to buy from whom.
Is this degradation of performance indicative of FPR failure?
Can FPR be tested on cold non running engine? Is looking for any fuel coming from FPR on cranking a valid test in this case?
If FPR is condemned, please confirm what part number and source I should procure from.
So grateful for any input that you may have on this scenario.
Back story.
Current status
New MAF ordered.
