Now that I've got you excited to see a custom 2.5L build.. Lets make you wait a little bit... How about we rebuild the PTO(Transfer case).. PTO is short for Power Take Off unit... I found using this term made it easier for finding parts and information...
Remember this leaky thing??
Lets tear it apart.. Good news it looks clean inside..
Make sure you take a punch, or in my case a chisels to mark the bearing caps before you pull them off.. They are machined to match the housing and need to be installed in the same orientation and place when things go back together.. This also leads me to talk about the upgraded bearing caps that are on the market... I researched these before diving into this.. I was finding enough reports of people spinning bearings and ruining the case, it made me decide against upgrading the caps.. I do drive the car hard, but I don't have plans for any major racing.. I believe the issue with the upgraded caps is to do with the machining.. Technically you should get things line bored if you put new caps on.. Spent 10 years working in specialty driveline/transmission shops rebuilding differentials..If you've ever built a differential.. You use all the same principals and procedures here..
The wear you see on the inside of my bearing caps, and case half, is from the bearing races slowly spinning over time... This slow movement is ok.. If you can feel ridges with your finger nail.. You've got problems.. In my case everything here was healthy..
While it was apart, I took the time to inspect the oil pump... Pay attention to how it comes apart when you take the snap ring off.. the washer is a belleville washer that goes back together only 1 way.. It's been to long now, so I can't remember which direction it goes back on..
The wear you see here on the pump gears is ok.. There's no ridges or anything like that which can be felt with a finger nail..
No wear here on the side of the pump gear.. This is important to check..
Don't forget to check the housing for wear.. Mine shown here is in good shape...
The inner pump gear has a step in the center.. So it can only be installed 1 way.. The outter pump gear can be installed 2 ways... The machined dot needs to be facing the cap/top..
I tore the whole PTO down and replaced all the seals.. Part of that was removing the pinion gear..
This is a crush washer.. If you are familiar with building differentials, you'll know what this crush washer is.. It's job is to help maintain proper pinion bearing pre-load... You'll want to order a new crush washer if you get this far into a build.. technically once crushed, it can't go back together again.. As you can see there's quite a height difference.. This takes a really strong impact gun to crush, or a big ass breaker bar with special tools to keep the pinion from turning.. I have been able to do some back yard work, to spread a crush washer and re-use it.. but it's not advised..
Pinion bearing pre-load gets set by checking rotational torque.. So you need the bearings lubricated by gear oil and an inch pound torque wrench like you see here.. 6 - 12 inch pounds is a good range for used bearings.. 20 - 28ish inch pounds for brand new bearings.. As new bearings "break in" they will loosen up to about 6 - 12inch pounds.. This is something you've gotta sneek up on while crushing the crush washer..
You should replace the pinion nut since it's a nylock one time use nut... If you don't.. You can "stake" it by using a chisel to indent the top, and use red lock tight.. you don't want this nut backing off..
Don't forget to replace the oil cooler seals.. when you do, there's a notch on the oil cooler.. It need to get lined up in the corresponding spot on the case..
And with some good quality RTV, everything is all back together... there's some extra details, but this covers most of what it takes to rebuild the PTO..
