Crazycanadian
With cylinder head #2 off at the machine shop I figured I could use cylinder head #1 to still do some mock up/fabrication work..
The bottom end was fully assembled, transmission bolted up.. You can see oil filter sandwich plate below the oil cooler, and the -4 an line ready to us for the turbo oil feed..
Got my big boy front mount intercooler mounted.. This was one of the pieces I recovered from the theft.. This intercooler and the T3/T4 hybrid turbo were meant for the Mx3 as part of it's SMF build progression... but that dream died back in 2018 when my best friend and racing partner passed away.. I figured why not re-purpose both for this build?
The FSWork manifold got ported out.. It was setup for a T25 turbo.. but I wanted to run the T3/T4 turbo.. I got a T3 flange and welded it to the cast manifold.. I did that by heating the manifold up in a small BBQ.. Once welded I put it back in the BBQ and turned it down, and then off using the radiant heat to control how quickly everything cooled off.. This looked like it worked well..
The "new" used gen2 motor came with a stock manifold.. I used that, with my stock turbo and stock down pipe to create the "wire mesh" as a way of fabricating a down pipe with out having to install the motor in the car.. I wasn't happy with this setup and scrapped it... I was having major trust issues.. That T3/T4 turbo might be brand new, but it was bought 10 years ago when cheep ebay turbos started flooding the market.. They were hit or miss in terms of quality... I didn't like the wastegate pipe setup.. It had no flex coupler. It had warped a bit during welding.. I didn't have the materials I wanted.. The OBX wastegate...... yaah... This was all old shit I wasn't really trusting anymore..
Here's a random picture of the turbo drain with the PTO bolted up.. it's tight, but clears just fine.. just above the support brace on the passenger side of the PTO is a better area to run the turbo drain.
Ok ok.. the engine bay looked pretty empty... I did tuck the motor in once with the T3/T4 turbo setup on it... If you zoom in you'll see the nicely ported intake ports of that botched cylinder head...
