Changed my mind on how I done the porting. Ended up cutting it back a little farther before the split starts. I haven’t done the floor yet but this is pretty much going to be shape. Also wanted to check the weight difference of the springs and retainers. Supertech 70lb dual springs VS stock. Actual valve train weight and spring pressure. The supertech came in at exactly 70lbs. The stock was 55lbs. The difference in weight was surprising to me being double spring VS a single spring. Supertech springs only weighed 4.72g more than the stock spring.
It’s alive!!! I finally got it up and running today. Took it for a short drive. Everything seems good so far BUT I have some electrical gremlins going on. The only window that works is the driver window. When I turn on the turn signal the rears work fine but the front left flashes no matter which way I turn it on and both dash indicators flash as if the 4 ways are on. And the AP shuts off and says the engine has been shut off but the car is still running. If I unplug it and plug it back in it starts working again. I’m still happy it’s running , now just have to work out the bugs and get some miles on it.
