phate
Motorhead
After buying a used trailer (circa 2001) and nuking some axles bearings, I sold it. I sold it with the intent of getting a new trailer before the next season. Thus, the queen needed a new throne.
I compared pricing and a fuckillion reviews before deciding to save some cash and get a trailer from Georgia. Now, if you know anything about Georgia trailers, you know there's a LOT of horror stories with them. I landed on Rock Solid brand enclosed trailers. They seemed to have the right combination of build materials and good reviews to make me feel pretty comfortable buying one. I had a few "must haves" on the trailer, and a few additional items that we would like to have, and decided to just custom order one. The lead time from order to pick up was 16 days.
The basics of the trailer:
8.5x28' enclosed Rock Solid Brand
The basics include a couple noteworthy items - 8" main beams. Most trailer manufacturers use 6" main beams up to ~30'. Rock Solid uses 8" on 26'+. 16" O/C floor studs - some manufacturers use 24". You can get tighter spacing for a cost, but I didn't think it was necessary.
The options:
Some suggestions for anyone ordering a trailer:
This thread will mostly be about how we modify the trailer to make it livable for race weekends. I'm starting with the floor and walls, then building in shelving and cabinets, and we are planning on RV style shower/toilet before next season.
The options:
- Flat front (for easier shelving and cabinetry)
- Add 6" to height (overall 7' interior height)
- 7000 lb torsion axles (because of GCWR things and CDL requirements, this will keep us under)
- I had 3500 lb axles on the last trailer and the bearings always ran HOT when loaded. I could cruise about 65 mph on a cool day without a problem, but would have to slow down on hot days. I ended up servicing the bearings a lot more than I should have. If you get an enclosed trailer, avoid 3500 lb axles like the plague, and upgrade to 5000+ lb axles.
- 7000 lb axles come standard with 16" wheels, where you get into a MUCH better tire. You can upgrade wheels on the 5-6k lb axles, but the price differential was a couple hundo between that and the 7k's, so we just spent the extra cash and went 7k.
- Escape door - for the most part these things are unusable as car escape doors. The inner fenders are too tall to open your door over, and our cars are too low. But, for resale reasons, I got one (everyone wants an escape door). They are GREAT for getting a cross breeze through a trailer, though.
- 48" ramp flap - standard is 16", and to have any hope of getting the car on without splitter disassembly, you need a longer ramp
- The ramp flap makes the door stupidly heavy, so get a double spring assist. We have a double spring on this one, and it's still pretty heavy.
- .040" exterior skin. Standard is .023" or .030", but we wanted a less wrinkly exterior.
- 1 piece aluminum roof - because leaks suck. I also deleted the roof vents so there isn't another potential leak point.
- Push out side vents - these things are pretty trick. They can open forward or backwards. They are a little small, I have one on the upper front left wall, and another on the lower rear right wall. I kinda wish I would have gotten 2 at the front and 2 at the rear.
- Dual LED taillights - Single tails can be a little hard to see (you can get however many you want)
- Winch Plate - Gives you something solid to mount a winch to.
- Steel transition flap - this little hinged flap covers the gap between the rear door and main compartment so you can roll stuff in and out more easily.
- Stabilizer jacks - so you don't lift the front end of the trailer when loading an unhooked trailer. Also gives the trailer a more solid feel when in the paddock.
- 8 total D-Rings - again, mostly for resale because everyone says they need more.
- Bogey wheels - why aren't these standard on big ass trailers? You will slam the ass end into steep inclines, and these wheels take the hit instead of the outer edge of the trailer. Just get these.
- Bar Locks on all doors in addition to just the RV locks - they're more secure, that's all.
- Spare tire - cheaper to do it here than afterwards
- Define exactly where you want the D Rings and Winch Plate (I drew them a diagram)
- Define where the side doors go - I was really surprised at how far forward the man door was. We didn't define it or even ask about it, so I didn't complain. But, if I could do it again, I would move the door away from the front end 3-4' - this is 16" away from the front wall.
