GCPhotographers
Is this worth doing on our stock TB or should we wait for CS to come out with the 72MM TB. Overall, is porting the TB worth it?
It's said that 650whp is the start of real power. I believe you can put porting heads with the tb because just a little clean up, charges the flow and results in a decent way.To be honest I'm pretty sure porting the throttle body isn't really worth it unless you are looking for big power and run larger IC pipes. Just like porting the head, not really worth it unless you're looking for big power.
Interesting. I'd really be interested to see how much more flow is made with a ported head at "minor" power levels vs a non ported head. From everything I've read, the gains are minimal but I've never actually seen the data to back that up. But I can't see a throttle body being worth porting unless you run larger IC pipes and are aiming for 550+. Again I can be completely wrong though.It's said that 650whp is the start of real power. I believe you can put porting heads with the tb because just a little clean up, charges the flow and results in a decent way.
We are on the same boat. I've been doing some studies on different platforms and with a machinist...they concluded that everything is situational and varies on every platform bigger bowl work etc means bigger valve set up needing a bigger intake along with the right oil and fueling. As a daily, it can be interesting within the right cooling set upInteresting. I'd really be interested to see how much more flow is made with a ported head at "minor" power levels vs a non ported head. From everything I've read, the gains are minimal but I've never actually seen the data to back that up. But I can't see a throttle body being worth porting unless you run larger IC pipes and are aiming for 550+. Again I can be completely wrong though.
I'm going to try it out and see. There is a shop out here that's been doing it for years. Let's see what happens. I'll share before and after photos.I agree. Might be time for some science.
That's what I was planning. I was going to send in an extra TB and compare everything and see what Hypnotic have to say.I will pose this question: anyone here actually had their TB ported? I had mine done on my 300ZX and it kicked ass. There is a shop that will port it and make a new butterfly for $125, a seemingly good price. I would be cool with scrounging up a salvaged TB and send it to them but I`d rather not piss away money if our cars don`t respond well to it.
I'd personally wait for that CorkSport 72mm throttle body. Initial testing looks rather promising I have to say.
I really can't imagine being able to port a stock throttle body much larger than it is already... Also, plenty of people are making power on stock TB so if I were you, I'd go along with a stock TB and then when it comes out, scoop it up and reap the large TB benefits!
But when is that gonna happen? #2weeks?
I'm not sure why you think I'd have that information!
It's our stock TBI'm interested to see how that works. What kind of tb is it?
