amnesiac
I'm having a problem with the car, and I'm hoping someone can help me out with troubleshooting steps to prove if the issue is with the transfer case or the rear diff.
The problem started today while driving. I felt a lurch and heard some banging/rattling sounds. I ended up pulling over and having the car towed to my house. Once there I did a little bit:
The car starts and idles fine. It shifts into all gears. Once you put it in a gear and start to let out on the clutch, the car will creep forward or reverse a little bit before it feels like something is binding up, and if you push the clutch in again the car will spring back the opposite direction. I put the car up on jackstands and rotated the wheels, all wheels rotate as expected with no abnormal sounds when the car is off. Once the car is on and you're attempting to operate it with the clutch/throttle, the problem appears. It happens in forward and reverse.
I removed the driveshaft. Once that was gone the car can move freely in forward and reverse under power. I think that would mean that the problem is inside either the rear diff or the transfer case, and I'm not sure what to do to isolate it in either direction. Any thoughts?
Thanks~
Thanks~
