INVALID
Can anyone identify what this noise potentially is?
The short of my long story is I had a plan of searching out and purchasing a cheap Speed 6 that I could pull the wire harness from along with any other needed parts, it would also be a good reference tool. But when the car arrived, I asked for assistance to push it into the garage and the transporter said it would actually start after putting a jump pack on it. It fired right up, but had a loud noise to it. I've been taking parts off it here and there to test on the primary Speed 6, then installing them back after purchasing a replacement for the primary Speed. With it being warmer outside I decided to put the spare battery on and start it up again to take another listen. The sound you hear is after I let out the clutch.
What do you think? After I get all the issues resolved on the primary Speed, I would like to do all the work on this Test Speed 6. For learning, money, and due to all the issues you didn't hear about, that I experienced from shops to get the primary in order.
