ConeKiller
Motorhead
I've heard that EFR's are rebuildable, but not end-user serviceable.Ball bearing turbos are rebuild-able too dont forget.
True, just pricier and require more skill to do so. (I learned that watching Turbolabs YT vidsBall bearing turbos are rebuild-able too dont forget.
@Enki turned me on to Matchbot: http://www.turbos.bwauto.com/aftermarket/matchbot.aspxQuick question; how do you guys compare turbos? Lbs/min? Inducer/exducer specs? Both? One or the other?
I personally look at both, compare to a precision that I know, and then Google 4 banger dynos with it.
And does anybody *really* know how to read compressor maps?![]()
It takes a little while to learn how to use it, but there are YT vids on doing so and it is extremely helpful in letting you know what to anticipate with a particular BW turbo on your car.
You'll get output like this: http://www.turbos.borgwarner.com/go/0GEM4A
The key is to input all of your car's variables and fine-tune the boost curve, etc., to see roundabout what to expect. It'll help you make sure you stay on the turbo's efficiency islands too, neither surging, nor choking.
[doublepost=1482305040][/doublepost]For instance, I'm not sure if I used the right compressor Phi curve, and I spitballed boost levels you may run; I also didn't enter your exact particulars, but you'll be well on the compressor islands @ 650/490 if you ran 35psi up top: http://www.turbos.borgwarner.com/go/XJ7D79
Just have to not WOT too low to avoid surge...
