Camel
Alright let me start off with "I'm a noob", I'm learning as I go and I'm happy to experiment with tuning since this is not my daily driver. That being said I've done a fair amount of troubleshooting and research and I'm unable to find a solid conclusion.
This is the mod list currently: 3" intake, CS Racepipe, muffler only, stock K04, Engine balancer delete, Autotech HPFP internals, NGK 1-step colder, Damond engine mounts and trans mount, Fidanza Lightweight flywheel, EGR delete, stock TMIC, stock EBCS, 150-152psi across all cylinders, 91 pump gas
What I've done hardware specific:
Found and fixed boost leak, VTCS solenoid bottom nipple was leaking.
Pressurized smoke test up to 20psi and no smoke was seen after fixing leak.
Found and fixed an exhaust leak between manifold to turbo flange, 2 of the 4 turbo flange bolts were basically dancing around.
found and fixed exhaust leak between turbo to downpipe flange, missing a nut and had a loose stud on the flange, torqued all loose bolts to spec. (exhaust leaks were also evident due to black soot on the heat shielding)
Verified EBCS solenoid activates and de actives when given 9 volts directly. (I can hear a little click and I was able to blow air through it when voltage was applied.)
Verified EBCS solenoid hose routing is correct, hose closest to EBCS harness connection goes to turbo wastegate actuator, hose closest to firewall goes to turbo inlet pipe.
Verified the waste gate actuator opened and closed smoothly when metered air pressure was attached.
I even pinched off the waste gate actuator from the EBCS and it made no difference in boost or load.
feels like WGDC isn't doing anything at all. I could try swapping EBCS solenoids from my other speed3, but I dont think the EBCS is the issue if giving it voltage directly makes a click and allows air to pass through.
What I've done software specific:
MAF is calibrated Okay +-5% LTFT
zeroed BCS DC Base table (no difference - 11-13 psi boost 1.6-1.7 load)
copy and pasted stock tune BCS DC Base table values (no difference - 11-13 psi boost 1.6-1.7 load)
copy and pasted VersaTuner 91 Octane BCS DC Base table values (no difference - 11-13 psi boost 1.6-1.7 load)
copy and pasted VersaTuner 93 Octane BCS DC Base table values (no difference - 11-13 psi boost 1.6-1.7 load)
increased APP Requested Load Normal / Overload values
increased Requested Load for 3rd and 4th gear Limit Low BAT values
Attached are both my latest tune file and a WOT log for that specific version tune file. Also (2) 3rd Gear WOT logs before and after the leaks were fixed on an earlier revision of the tune file.
I'm down to these conclusions:
I have a leak somewhere still (Could my turbo wastegate flapper be cracked open and slightly leaking enough to limit boost?)
I do not know how to use VersaTuner AT ALL and I'm just missing something very small but crucial. (very likely)
I'm desperate for help lol, I've googled, I've chatgpt'd it, browsed versatune forums, mazdaspeeds forums, I've tried using common sense, and even after fixing what I thought was the issue ended up being not making a difference at all.
Any help is appreciated, I hope everyone had a merry christmas and a happy new year when that rolls around!
