I'm going to incorporate an AFR failsafe besides my GA. Have you thought about going that route? (Getting an AEM AFR failsafe, too?) I'm definitely going to have an AFR monitor since I'll be methanol fueling-dependent. I want a split-second intervention if I suddenly go lean under full boost, you know?Interesting info to know, but for practicality reasons I have another solution. Just going to have the GA failsafe trigger a relay and cut power to the meth controller.
Ahhhh, so there may have been both hydrolock and overboost going on. You wouldn't been able to see anything over ~30psi due to having a 3-Bar. Heck, you could've spiked much, much higher.Not so much hydrolock. More like an over exaggerated wotbox effect. A wotbox works by cutting spark between shifts so the cylinder is full of fuel and makes a bigger flame, forcing spool. When I hit the rev limiter the ECU cut spark and fuel, but methanol kept spraying as it was still in boost (albeit declining). When the spark came back on the cylinder was full of methanol and ignited an enormous flame front, going mega-spool.
As far as VT, I`m only just getting more familiar with the nitty gritty of it but I do know I can set up the conditions under which it goes to fuel cut. There may well even be a way for it to dump WGDC if it goes lean, which would kick ass.
He isnt spraying nearly enough meth for hydrolock
Good to know. Must've been just overboost that made rod 1 turn into a contortionist.20gph is a lot, but not enough to hydrolock a running motor.
Let's get it on the road man! Gonna be done in time for your trip?
What's the ETA then on getting the car back? They going to tune it possibly still?No, but yes. I would have left day after tomorrow, so no. But I can reschedule the trip so yes.
How much was their dyno estimate? Btw, freek does dyno tuning just have to schedule it.Middle /end of next week as long as the head makes it back from the machine shop. It's done, they just pick up work in batches (which I understand despite it hold up my build). After running the last logs and getting the dyno estimate it gave I don't think I'm going to have them tune it. They will be doing the dyno break in so it's ready to rock but we're just going to convert the previous map to VT for the new motor and dial it in from there. If the 460/420 numbers are close I'll be really happy.
Sent from my SM-G360T using Tapatalk
