You really don't want to use a fram oil filter
OEM filter is like 9$ on amazon isn't itThe use cheaper materials and the bypass spring is weaker than most other brands. Meaning that most of the time you are using it there is no filtering just bypass
Use either a wix or motorcraft about the same price and much Bette quality
Great choice, S3 is great, spools at about 3500rpm for me. Curious what the powerband is like on the S2?Well I just finished up installing a Cobb catted DP and a JBR 3.5 intake on the car along with a 3 BAR MAP sensor. The plan was to open up my exhaust and intake and see what the S2 Gen2 could do and then I did a thing.....
I was perusing Ebay and saw a brand new in the box BNR S3 for a price I couldn't say no to so I bought it. I guess I get to undo all the work I just did!
At least now I can actually use some of the potential of this built motor. I'm absolutely going to run E30 once I finish up my 93 tune. Should be a fun summer I'm looking forward to having a "Fast" Speed3.
I'm using that term loosely also as I've seen what some of you maniacs have going on!
So I haven't tapped the full potential of the S2 because I was on a small intake and the OEM DP. I was planning to retune and see what would happen on new parts.Great choice, S3 is great, spools at about 3500rpm for me. Curious what the powerband is like on the S2?
Well you know I never even considered thatIs ABS good to above underhood temps? Le google has it listed as ~221 deg F before fun things start happening.
