SamuSpeed
After a compression test in cylinder 4 , that result as 200 psi. I put the camera inside and i found it like this, the sparkplig is dry and good btw, it could be a bad injector while i was doing the compression test? I didnt unplug the pump relay, i just hold the throttle , maybe not that good, so compression is perfect, spark plug too..and the car isnt smoking.
