I have considered that, I just need to check and make sure that method would be blessed.Throw some sticky weights at it.
I didn't break any of the little teeth, but I took a chunk out of the base prying it off.That fucking clip.
Sent from my XT1575 using Tapatalk
Will do. New vac hose, hose t, and wiring arriving tomorrow. Oil pressure won't be fully operational until next oil change.Do write a quick review here after you've hooked it up.
I'm surprised Corksport hasn't yet made a post here about these gauges. I only came across them on FB.
.... one of the torx crows feet bolts melted like butter and is now stripped. I'm deciding how I'm going to get it out, but put the car back together for that.
Mine looked the same, also my TMM had some tearing starting in the rubber. I'm not making big power either, maybe 300 wheel. The factory mounts really are inadequate if you drive spirited much at all.Between the recent PMM swaps by myself and @Darthxar if one actually needs justification to swap out the PMM for a better unit here's a pic of my OEM mount before it went to storage. That's a lot of movement when the center portion of the mount hits the aft side and the normal gap is better than 3/16".
Non-stock PCV valve? My new OEM one from Edge was green/orange...Swapped out the pcv plate and was going to do injector seals until one of the torx crows feet bolts melted like butter and is now stripped. I'm deciding how I'm going to get it out, but put the car back together for that.
crapatalk, yes it sucks for free.
I picked it up second hand from a Nator Co member. He had it for a year on his 6 so I'm not sure what he ordered. It works well though with my check valve.Non-stock PCV valve? My new OEM one from Edge was green/orange...
One step closer. Power wired, but no sensor connections yet.
Or maybe you could just dump a ton of octane booster into the tank, watch KR carefully, and run it until you can refill with a new tank of premium?Not necessarily something I did, but the dipshit that put gas in my car decided to fill the speed with 87 octane today. Looks like I'll be dropping the tank tomorrow if I can't get much out of the manager at gas station tomorrow. Super stoked!
Can you get your hands on a shaker siphon that'll fit through the filler hole? If you can get most of the fuel out you should be safe. Do you have E-85 available? That might help if you can't get all of out as well.
