Basically, once you're above the boost threshold, when you WOT, you'll spool as fast as that particular turbo will allow. This has a lot to do with the mass of the CHRA and its resulting inertia. Bigger turbine/compressor wheels have more inertia, everything else being equal, so the spool isn't as quick. Also, twinscroll setups lower the boost threshold by pairing the appropriate cylinders and effectively channel/synchronize sufficient exhaust gasses to reach boost threshold at a lower rpm.this is what has always confused me. I can probably hit 20psi below 3000 rpm if I want. I just have to floor it at 2000 and there it goes. I know there will be a lower threshold of where the exhaust gasses can move the turbine wheel, but going WOT at 2500 still gets me 20 psi by 3200. I feel like there needs to be a common starting point.
[doublepost=1471026893][/doublepost]
I guess Ive never kept going down in RPM to see where it cant spool just as fast. Never wanted to floor it before 2500 rpm
Now if you WOT below the boost threshold, you'll see very little boost level climbing until you reach the point that the combustion gasses are sufficient to spool the turbo. That's what sometimes throws people off. The interplay between boost threshold and spool has a significant impact on driving experience. That's why I love my BNR S3. I never WOT below its boost threshold because stock block. And it'll spool just as quickly at 3k as it will at any engine speed above 3k because the engine is pumping enough exhaust gasses to have eclipsed the boost threshold.
