Castillo817
Def will have vids. Probably going to make some progress vids and upload them on YouTube lolI'm looking forward to this! We need noise clips when she's running
Lol right. Tomorrow I'll see if I will start cleaning the k member and remove unnecessary wiring/hardware.Well it's about time. Lol
The answer is always Miata! So you are going to attempt to modify the stock subframe? You could always get a mountless subframe from V8R and make your own mounting location.
So not to derail the thread, however since the topic was brought up I figured I would give my two cents, in regards to the DISI in a Miata, I don't think that is as farfetched as one might think. Rokusek and I were actually talking about this the other day, I believe you could use the mountless subframe I mentioned above from V8 Roadster, get the DISI mounted on the subframe (or even potentially source a subframe and modify from NC, not sure how well that would work) you could then use a variety of different transmissions, the NC trans, a Ford Ranger trans, or have an adapter plate made for an RX7 TII transmission which already has a PPF solution, that gets the engine and trans into the car which is half the battle. You could use a full standalone for it, or you could use the ECU from a PU. If one can put a V8 into a Miata, I don't see how anything else would not fit for any reason, hell there are K swapped Miatas, Honda V6 motors in Miatas, like I said, the answer is always Miata
Best of luck with everything, I look forward to progress!
swapping the DISI in doesnt make sense to me, the NC already has a MZR, with port injection, i think it would be easier to turbo the NA motor than deal with getting the ECU to work. Also the MS3 ECU wont work without the instrument cluster
Standalone, man. If you're going to do an engine swap like this anyways, get a Haltech or another standalone. Problem solved. Added benefit is many of them support Flexfuel sensors and can adjust timing/boost progressively based on your specific ethanol ratio.swapping the DISI in doesnt make sense to me, the NC already has a MZR, with port injection, i think it would be easier to turbo the NA motor than deal with getting the ECU to work. Also the MS3 ECU wont work without the instrument cluster
I would like to put a DISI into an rx-8 personally, make the world beating super car mazda should have.
same company makes the best chassis and best motor at the same time and doesnt bolt them together, complete and utter shame.
plus rx-8's are really cheap right now
I'm thinking maybe the Miata box would have too short gears that couldn't handle the MZR DISI power?DISI swapped RX8 with an NC Miata trans would be ideal
The 6 speed manual that comes with the 2.0 has fairly similar ratios as the first gen speed transI'm thinking maybe the Miata box would have too short gears that couldn't handle the MZR DISI power?
