Riley Mayo
Hey guys, I’m just getting around to installing my AEM meth kit, I’ve got my tank & pump mounted, my wires/hoses ran through my firewall, and will be mounting the controller in the glovebox.
Now, my question, The AEM Controller has a boost reference hose, that connects to the controller & runs to a (boost reference)
I am just curious where this boost reference should be? I assume I will be using the Tee fitting supplied by AEM and tapping into one of my EBCS lines. Just unsure as to which line to use. The EBCS is set up in 3 port mode also. Should I reference the waste-gate actuator line, turbo compressor line, or intake line? Thanks in advance, any & all help is much appreciated. Thanks guys!
